Generalized monoidal effects and handlers - Archive ouverte HAL Access content directly
Journal Articles Journal of Functional Programming Year : 2020
(1) , (2) , (1)
1
2
Algebraic effects and handlers are a convenient method for structuring monadic effects with primitive effectful operations and separating the syntax from the interpretation of these operations. However, the scope of conventional handlers is limited as not all side effects are monadic in nature. This paper generalizes the notion of algebraic effects and handlers from monads to generalized monoids, which notably covers applicative functors and arrows as well as monads. For this purpose, we switch the category theoretical basis from free algebras to free monoids. In addition, we show how lax monoidal functors enable the reuse of handlers and programs across different computation classes, for example, handling applicative computations with monadic handlers. We motivate and present these handler interfaces in the context of build systems. Tasks in a build system are represented by a free computation and their interpretation as a handler. This use case is based on the work of Mokhov et al. [(2018). PACMPL2(ICFP), 79:1–79:29.].
Not file
Dates and versions
hal-03112837 , version 1 (17-01-2021)
Identifiers
Cite
Ruben Pieters, Exequiel Rivas, Tom Schrijvers. Generalized monoidal effects and handlers. Journal of Functional Programming, 2020, 30, ⟨10.1017/S0956796820000106⟩. ⟨hal-03112837⟩
Collections
INRIA INRIA2
57 View
0 Download
Share
