Complete trace models of state and control (full version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We consider a hierarchy of four typed call-by-value languages with either higher-order or ground-type references and with either callcc or no control operator. Our first result is a fully abstract trace model for the most expressive setting, featuring both higher-order references and callcc, constructed in the spirit of operational game semantics. Next we examine the impact of suppressing higher-order references and callcc in contexts and provide an operational explanation for the game-semantic conditions known as visibility and bracketing respectively. This allows us to refine the original model to provide fully abstract trace models of interaction with contexts that need not use higher-order references or callcc. Along the way, we discuss the relationship between error- and termination-based contextual testing in each case, and relate the two to trace and complete trace equivalence respectively. Overall, the paper provides a systematic development of operational game semantics for all four cases, which represent the state-based face of the so-called semantic cube.
esop.pdf (566.59 Ko) Télécharger le fichier
hal-03116698 , version 1 (20-01-2021)
Guilhem Jaber, Andrzej S. Murawski. Complete trace models of state and control (full version). 2021. ⟨hal-03116698⟩
284 Consultations
142 Téléchargements
