Decentralized SDN Control Plane for a Distributed Cloud-Edge Infrastructure: A Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications Surveys and Tutorials, IEEE Communications Society Année : 2021
Today’s emerging needs (Internet of Things applications, Network Function Virtualization services, Mobile Edge computing, etc.) are challenging the classic approach of deploying a few large data centers to provide cloud services. A massively distributed Cloud-Edge architecture could better fit these new trends’ requirements and constraints by deploying on-demand infrastructure services in Point-of-Presences within backbone networks. In this context, a key feature is establishing connectivity among several resource managers in charge of operating, each one a subset of the infrastructure. After explaining the networking management challenges related to distributed Cloud-Edge infrastructures, this article surveys and analyzes the characteristics and limitations of existing technologies in the Software Defined Network field that could be used to provide the intersite connectivity feature. We also introduce Kubernetes, the new de facto container orchestrator platform, and analyze its use in the proposed context. This survey is concluded by providing a discussion about some research directions in the field of SDN applied to distributed Cloud-Edge infrastructures’ management.
Decentralized_SDN_Control_Plane_for_a_Distributed_Cloud_Infrastructure__A_Survey(3).pdf (576.04 Ko) Télécharger le fichier
hal-03119901 , version 1 (26-01-2021)
David Espinel Sarmiento, Adrien Lebre, Lucas Nussbaum, Abdelhadi Chari. Decentralized SDN Control Plane for a Distributed Cloud-Edge Infrastructure: A Survey. Communications Surveys and Tutorials, IEEE Communications Society, 2021, IEEE Communications Surveys & Tutorials, 23 (1), pp.256-281. ⟨10.1109/COMST.2021.3050297⟩. ⟨hal-03119901⟩
232 Consultations
2286 Téléchargements
