Confluence in Non-Left-Linear Untyped Higher-Order Rewrite Theories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We develop techniques based on van Oostrom's decreasing diagrams that reduce confluence proofs to the checking of critical pairs for higher-order rewrite rules extending betareduction on pure lambda-terms. We show that confluence is preserved for a large subset of terms that contains all pure lambda terms. Our results are applied to famous Klop's examples of non-confluent behaviours in lambda-calculi with convergent rewrite rules, on the one hand, and to fragments of an encoding in a dependent type theory augmented with rewrite rules of the Calculus of Constructions with polymorphic universes.
ppdp2021-9.pdf (893.62 Ko) Télécharger le fichier
hal-03126115 , version 1 (01-02-2021)
hal-03126115 , version 2 (22-02-2021)
hal-03126115 , version 3 (03-03-2021)
hal-03126115 , version 4 (25-05-2021)
hal-03126115 , version 5 (21-07-2021)
hal-03126115 , version 6 (14-09-2021)
Gaspard Férey, Jean-Pierre Jouannaud. Confluence in Non-Left-Linear Untyped Higher-Order Rewrite Theories. PPDP 2021 - 23rd International Symposium on Principles and Practice of Declarative Programming, Sep 2021, Tallin, Estonia. ⟨10.1145/3479394.3479403⟩. ⟨hal-03126115v6⟩
373 Consultations
508 Téléchargements
