Recommendations for a radically secure ISA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The rising number of attacks targeting processors at micro-architecture level encourages more research on hardware level solutions. In this position paper, we specify a new RV32S “secure” instruction set architecture (ISA) derived from the RV32I RISC-V ISA. We propose modifications in the ISA to prevent timing side-channels, strengthen control flow integrity and ensure micro-architectural state isolation. The goal is to provide a new minimal hardware/software approach through which software attacks exploiting hardware vulnerabilities can be circumvented.
carrv.pdf (495.68 Ko) Télécharger le fichier
hal-03128242 , version 1 (05-02-2021)
  • HAL Id : hal-03128242 , version 1
Mathieu Escouteloup, Ronan Lashermes, Jean-Louis Lanet, Jacques Jean-Alain Fournier. Recommendations for a radically secure ISA. CARRV 2020 - Workshop on Computer Architecture Research with RISC-V, May 2020, Valence (virtual), Spain. pp.1-22. ⟨hal-03128242⟩
225 Consultations
335 Téléchargements
