Philosophers may Dine - Definitively!
The theory of Communicating Sequential Processes going
back to Hoare and Roscoe is still today one of the reference theories for
concurrent specification and computing. In 1997, a first formalization in
Isabelle/HOL of the denotational semantics of the Failure/Divergence
Model of CSP was undertaken; in particular, this model can cope with
infinite alphabets, in contrast to model-checking approaches limited to
finite ones. In this paper, we extend this theory to a significant degree
by taking advantage of more powerful automation of modern Isabelle
version, which came even closer to recent developments in the semantic
foundation of CSP.
More importantly, we use this formal development to analyse a family
of refinement notions, comprising classic and new ones. This analysis
enabled us to derive a number of properties that allow to deepen the understanding of these notions, in particular with respect to specification
decomposition principles in the infinite case. Better definitions allow to
clarify a number of obscure points in the classical literature, for example concerning the relationship between deadlock- and livelock-freeness.
As a result, we have a modern environment for formal proofs of concurrent systems that allow to combine general infinite processes with
locally finite ones in a logically safe way. We demonstrate a number
of verification-techniques for classical, generalized examples: The CopyBuffer and Dijkstra’s Dining Philosopher Problem of an arbitrary size.
