Elimination ideals and Bezout relations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algebra Année : 2020
Let $k$ be an infinite field and $I\subset k [x_1, \ldots ,x_n]$ be a non-zero ideal such that dim $V (I) = q $. Denote by $(f_1; : : : ; s)$ a set of generators of $I$. One can see that in the set $I\cap k [x_{1},...,x_{q+1}]$ there exist non-zero polynomials, depending only on these $q+1$ variables. We aim to bound the minimal degree of the polynomials of this type, and of a Bézout (i.e. membership) relation expressing such a polynomial as a combination of the$f_i$. We also give a relative version of this theorem.
galigojelonek.pdf (212.08 Ko) Télécharger le fichier
hal-03138363 , version 1 (19-02-2021)
Zbigniew Jelonek, André Galligo. Elimination ideals and Bezout relations. Journal of Algebra, 2020, 562, pp.621-626. ⟨10.1016/j.jalgebra.2020.06.022⟩. ⟨hal-03138363⟩
52 Consultations
61 Téléchargements
