Moderate Deviations for the SSEP with a Slow Bond - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Statistical Physics Année : 2021
Xiaofeng Xue
  • Fonction : Auteur
  • PersonId : 1087943
Linjie Zhao
  • Fonction : Auteur
  • PersonId : 1091255
We consider the one dimensional symmetric simple exclusion process with a slow bond. In this model, particles cross each bond at rate N^2 , except one particular bond, the slow bond, where the rate is N. Above, N is the scaling parameter. This model has been considered in the context of hydrodynamic limits, fluctuations and large deviations. We investigate moderate deviations from hydrodynamics and obtain a moderate deviation principle.
MDSSEPSB_revisedversion.pdf (213.13 Ko) Télécharger le fichier
hal-03145320 , version 1 (18-02-2021)
  • HAL Id : hal-03145320 , version 1
Xiaofeng Xue, Linjie Zhao. Moderate Deviations for the SSEP with a Slow Bond. Journal of Statistical Physics, 2021. ⟨hal-03145320⟩
57 Consultations
35 Téléchargements
