HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
ESTOCADA: Towards Scalable Polystore Systems
Abstract : Big data applications increasingly involve diverse datasets, conforming to different data models. Such datasets are routinely hosted in heterogeneous stores, each capable of handling one or a few data models, and each efficient for some, but not all, kinds of data processing. Systems capable of exploiting disparate data in this fashion are usually termed polystores. A current limitation of polystores is that applications are written taking into account which part of the data is stored in which store and how. This fails to take advantage of (i) possible redundancy, when the same data may be accessible (with different performance) from distinct data stores; (ii) previous query results (in the style of materialized views), which may be available in the stores. We propose to demonstrate ESTOCADA [4], a novel approach that can be used in a polystore setting to transparently enable each query to benefit from the best combination of stored data and available processing capabilities. The system leverages recent advances in the area of view-based query rewriting under constraints, which we use to describe the various data models and stored data.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03150404
Contributor : Ioana Manolescu Connect in order to contact the contributor
Submitted on : Tuesday, February 23, 2021 - 5:31:30 PM
Last modification on : Thursday, February 3, 2022 - 11:17:23 AM
Long-term archiving on: : Monday, May 24, 2021 - 8:49:19 PM
File
p1241-alotaibi.pdf
Identifiers
Citation
Rana Alotaibi, Bogdan Cautis, A. Deutsch, Moustafa Latrache, Ioana Manolescu, et al.. ESTOCADA: Towards Scalable Polystore Systems. Proceedings of the VLDB Endowment (PVLDB), VLDB Endowment, 2020, 13 (12), pp.2949-2952. ⟨10.14778/3415478.3415516⟩. ⟨hal-03150404⟩
Share
Metrics
Record views
42
Files downloads
165
