HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
A Replication Study on Glanceable Visualizations: Comparing Different Stimulus Sizes on a Laptop Computer
Tanja Blascheck 1 Petra Isenberg 2
2 AVIZ - Analysis and Visualization
Inria Saclay - Ile de France, LISN - Laboratoire Interdisciplinaire des Sciences du Numérique, IaH - Interaction avec l'Humain
Abstract : We replicated a smartwatch perception experiment on the topic of glanceable visualizations. The initial study used a setup that involved showing stimuli on an actual smartwatch attached to a wooden stand and a laptop to run and log the experiment and communicate with the smartwatch. In our replication we wanted to test whether a much simpler setup that involved showing the same stimuli on a laptop screen with similar pixel size and density would lead to similar results. We also extended the initial study by testing to what extent the size of the stimulus played a role for the results. Our results indicate that the general trends observed in the original study mostly held also on the larger display, with only a few differences in certain conditions. Yet, participants were slower on the large display. We also found no evidence of a difference for the two different stimulus display sizes we tested. Our study, thus, gives evidence that simulating smartwatch displays on laptop screens with similar resolution and pixel size might be a viable alternative for smartwatch perception studies with visualizations.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03151924
Contributor : Petra Isenberg Connect in order to contact the contributor
Submitted on : Thursday, February 25, 2021 - 10:33:51 AM
Last modification on : Thursday, February 3, 2022 - 11:17:24 AM
Long-term archiving on: : Wednesday, May 26, 2021 - 6:23:56 PM
Blascheck_2021_ACS.pdf
Identifiers
Citation
Tanja Blascheck, Petra Isenberg. A Replication Study on Glanceable Visualizations: Comparing Different Stimulus Sizes on a Laptop Computer. IVAPP 2021 - 12th International Conference on Computer Vision, Imaging and Computer Graphics Theory and Applications, Feb 2021, Virtual, Austria. pp.133-143, ⟨10.5220/0010328501330143⟩. ⟨hal-03151924⟩
Share
Metrics
Record views
101
Files downloads
276
