The SARS-CoV-2 Subgenome Landscape and its Novel Regulatory Features - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Molecular Cell Année : 2021
Dehe Wang
  • Fonction : Auteur
Ao Jiang
  • Fonction : Auteur
Jiangpeng Feng
  • Fonction : Auteur
Guangnan Li
  • Fonction : Auteur
Dong Guo
  • Fonction : Auteur
Muhammad Sajid
  • Fonction : Auteur
Kai Wu
  • Fonction : Auteur
Qiuhan Zhang
  • Fonction : Auteur
Yann Ponty
Feiyan Liu
  • Fonction : Auteur
Xinghai Yu
  • Fonction : Auteur
Shaopeng Li
  • Fonction : Auteur
Qianyun Liu
  • Fonction : Auteur
Xing-Lou Yang
  • Fonction : Auteur
Ming Guo
  • Fonction : Auteur
Xingqiao Li
  • Fonction : Auteur
Mingzhou Chen
  • Fonction : Auteur
Zheng-Li Shi
  • Fonction : Auteur
Ke Lan
  • Fonction : Auteur
  • PersonId : 1093169
Yu Chen
  • Fonction : Auteur
  • PersonId : 1093170
Yu Zhou
COVID-19, caused by Coronavirus SARS-CoV-2, is now in global pandemic. Coronaviruses are known to generate negative subgenomes through Transcription-Regulating Sequence (TRS)-dependent template switch, but the global dynamic landscapes of coronaviral subgenomes and regulatory rules remain unclear. Here, using NGS short-read and Nanopore long-read sequencing to profile poly(A) RNAs in two cell types at multiple time points post-infection of SARS-CoV-2, we identified hundreds of template switches and constructed the dynamic landscapes of SARS-CoV-2 subgenomes. Interestingly, template switch could occur in bidirectional manner, with diverse SARS-CoV-2 subgenomes generated from successive template switching events. Majority of template switches result from RNA-RNA interactions, including seed and compensatory modes, with terminal pairing status as a key determinant. Moreover, two TRS-independent template switch modes are also responsible for subgenome biogenesis. Collectively, our findings reveal the subgenome landscape of SARS-CoV-2 and its regulatory features, providing a molecular basis for the organization and regulation of coronaviral subgenomes.
main.pdf (5.33 Mo) Télécharger le fichier
hal-03154155 , version 1 (03-03-2021)
hal-03154155 , version 2 (10-03-2021)
Dehe Wang, Ao Jiang, Jiangpeng Feng, Guangnan Li, Dong Guo, et al.. The SARS-CoV-2 Subgenome Landscape and its Novel Regulatory Features. Molecular Cell, In press, ⟨10.1016/j.molcel.2021.02.036⟩. ⟨hal-03154155v2⟩
161 Consultations
114 Téléchargements
