Zoetrope Genetic Programming for Regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aurélie Boisbunon
  • Fonction : Auteur
  • PersonId : 910949
Carlo Fanara
  • Fonction : Auteur
Ingrid Grenet
  • Fonction : Auteur
Jonathan Daeden
  • Fonction : Auteur
Alexis Vighi
  • Fonction : Auteur
  • PersonId : 1092307
Marc Schoenauer
The Zoetrope Genetic Programming (ZGP) algorithm is based on an original representation for mathematical expressions, targeting evolutionary symbolic regression. The zoetropic representation uses repeated fusion operations between partial expressions, starting from the terminal set. Repeated fusions within an individual gradually generate more complex expressions, ending up in what can be viewed as new features. These features are then linearly combined to best fit the training data. ZGP individuals then undergo specific crossover and mutation operators, and selection takes place between parents and offspring. ZGP is validated using a large number of public domain regression datasets, and compared to other symbolic regression algorithms, as well as to traditional machine learning algorithms. ZGP reaches state-of-theart performance with respect to both types of algorithms, and demonstrates a low computational time compared to other symbolic regression approaches.
ZGP_regression_arxiv.pdf (1.63 Mo) Télécharger le fichier
PMLB-reg-SR_r2-time.pdf (545.12 Ko) Télécharger le fichier
PMLB-reg-SR_r2-time_zoom.pdf (536.87 Ko) Télécharger le fichier
hal-03155694 , version 1 (02-03-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Aurélie Boisbunon, Carlo Fanara, Ingrid Grenet, Jonathan Daeden, Alexis Vighi, et al.. Zoetrope Genetic Programming for Regression. GECCO 2021, ACM, Jul 2021, Lille, France. pp.776-784. ⟨hal-03155694⟩
211 Consultations
214 Téléchargements
