HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Challenging common bolus advisor for self-monitoring type-I diabetes patients using Reinforcement Learning
Abstract : Patients with diabetes who are self-monitoring have to decide right before each meal how much insulin they should take. A standard bolus advisor exists, but has never actually been proven to be optimal in any sense. We challenged this rule applying Reinforcement Learning techniques on data simulated with T1DM, an FDA-approved simulator developped by [3] modeling the gluco-insulin interaction. Results show that the optimal bolus rule is fairly different from the standard bolus advisor, and if followed can actually avoid hypoglycemia episodes.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-03161776
Contributor : Erwan Le Pennec Connect in order to contact the contributor
Submitted on : Monday, March 8, 2021 - 9:33:08 AM
Last modification on : Friday, February 4, 2022 - 3:09:08 AM
Long-term archiving on: : Wednesday, June 9, 2021 - 6:16:50 PM
File
2020-LLPAB-DSHealth.pdf
Identifiers
Citation
Frédéric Logé, Erwann Le Pennec, Habiboulaye Amadou-Boubacar. Challenging common bolus advisor for self-monitoring type-I diabetes patients using Reinforcement Learning. DSHeath, 2020, San Diego, United States. ⟨10.1145/nnnnnnn.nnnnnnn⟩. ⟨hal-03161776⟩
Share
Metrics
Record views
29
Files downloads
133
