A general stochastic matching model on multigraphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ALEA : Latin American Journal of Probability and Mathematical Statistics Année : 2021
We extend the general stochastic matching model on graphs introduced in [13], to matching models on multigraphs, that is, graphs with self-loops. The evolution of the model can be described by a discrete time Markov chain whose positive recurrence is investigated. Necessary and sufficient stability conditions are provided, together with the explicit form of the stationary probability in the case where the matching policy is 'First Come, First Matched'.
MultigraphBMMR_Final.pdf (397.16 Ko) Télécharger le fichier
hal-03168254 , version 1 (12-03-2021)
Jocelyn Begeot, Irène Marcovici, Pascal Moyal, Youssef Rahme. A general stochastic matching model on multigraphs. ALEA : Latin American Journal of Probability and Mathematical Statistics, 2021, 18 (2), pp.1325-1351. ⟨10.30757/ALEA.v18-49⟩. ⟨hal-03168254⟩
95 Consultations
53 Téléchargements
