The perturbed prox-preconditioned spider algorithm: non-asymptotic convergence bounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A novel algorithm named Perturbed Prox-Preconditioned SPIDER (3P-SPIDER) is introduced. It is a stochastic variancereduced proximal-gradient type algorithm built on Stochastic Path Integral Differential EstimatoR (SPIDER), an algorithm known to achieve near-optimal first-order oracle inequality for nonconvex and nonsmooth optimization. Compared to the vanilla prox-SPIDER, 3P-SPIDER uses preconditioned gradient estimators. Preconditioning can either be applied "explicitly" to a gradient estimator or be introduced "implicitly" as in applications to the EM algorithm. 3P-SPIDER also assumes that the preconditioned gradients may (possibly) be not known in closed analytical form and therefore must be approximated which adds an additional degree of perturbation. Studying the convergence in expectation, we show that 3P-SPIDER achieves a near-optimal oracle inequality O(n^(1/2) /epsilon) where n is the number of observations and epsilon the target precision even when the gradient is estimated by Monte Carlo methods. We illustrate the algorithm on an application to the minimization of a penalized empirical loss.
FMtheory_HAL.pdf (164.83 Ko) Télécharger le fichier
hal-03183775 , version 1 (28-03-2021)
hal-03183775 , version 2 (24-05-2021)
  • HAL Id : hal-03183775 , version 2
Gersende Fort, E Moulines. The perturbed prox-preconditioned spider algorithm: non-asymptotic convergence bounds. SSP 2021 - IEEE Statistical Signal Processing Workshop, Jul 2021, Rio de Janeiro, Brazil. ⟨hal-03183775v2⟩
146 Consultations
113 Téléchargements
