Thermal design power and vectorized instructions behavior - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Concurrency and Computation: Practice and Experience Année : 2022
In this paper, we study and compare the impact of thermal design power and SIMD instructions on performance, power and energy consumption of processors and memory. The study is performed on three different architectures providing different characteristics and four applications with different profiles (including one application with different phases, each phase having a different profile). The study shows that, because of processor frequency, performance and power consumption are strongly related to thermal design power. It also shows that AVX512 has unexpected behavior regarding processor power consumption, while DRAM power consumption is impacted by SIMD instructions because of the generated memory throughput. Finally, this paper tackles the impact of turboboost which shows equivalent to better performance for all the studied cases while not always decreasing energy consumption.
paper.pdf (489.88 Ko) Télécharger le fichier
hal-03185821 , version 1 (30-03-2021)
Amina Guermouche, Anne-Cécile Orgerie. Thermal design power and vectorized instructions behavior. Concurrency and Computation: Practice and Experience, 2022, 34 (2), pp.1-18. ⟨10.1002/cpe.6261⟩. ⟨hal-03185821⟩
Relations
238 Consultations
317 Téléchargements
