Extensional Denotational Semantics of Higher-Order Probabilistic Programs, Beyond the Discrete Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We describe a mathematical structure that can give extensional denotational semantics to higher-order probabilistic programs. It is not limited to discrete probabilities, and it is compatible with integration in a way the models that have been proposed before are not. It is organised as a model of propositional linear logic in which all the connectives have intuitive probabilistic interpretations. In addition, it has least fixed points for all maps, so it can interpret recursion.
geoffroy-21-convex-qbs.pdf (272.05 Ko) Télécharger le fichier
hal-03187624 , version 1 (06-04-2021)
hal-03187624 , version 2 (12-04-2021)
Guillaume Geoffroy. Extensional Denotational Semantics of Higher-Order Probabilistic Programs, Beyond the Discrete Case. 2021. ⟨hal-03187624v2⟩
41 Consultations
58 Téléchargements
