Learning to Jointly Deblur, Demosaick and Denoise Raw Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We address the problem of non-blind deblurring and demosaicking of noisy raw images. We adapt an existing learningbased approach to RGB image deblurring to handle raw images by introducing a new interpretable module that jointly demosaicks and deblurs them. We train this model on RGB images converted into raw ones following a realistic invertible camera pipeline. We demonstrate the effectiveness of this model over two-stage approaches stacking demosaicking and deblurring modules on quantitive benchmarks. We also apply our approach to remove a camera's inherent blur (its colordependent point-spread function) from real images, in essence deblurring sharp images.
eg_arxiv_version.pdf (3.03 Mo) Télécharger le fichier
hal-03197462 , version 1 (13-04-2021)
  • HAL Id : hal-03197462 , version 1
Thomas Eboli, Jian Sun, Jean Ponce. Learning to Jointly Deblur, Demosaick and Denoise Raw Images. 2021. ⟨hal-03197462⟩
79 Consultations
186 Téléchargements
