Quotient-space boundary element methods for scattering at complex screens - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BIT Numerical Mathematics Année : 2021
A complex screen is an arrangement of panels that may not be even locally orientable because of junction lines. A comprehensive trace space framework for first-kind variational boundary integral equations on complex screens has been established in Claeys and Hiptmair (Integr Equ Oper Theory 77:167–197, 2013. https://doi.org/10.1007/s00020-013-2085-x) for the Helmholtz equation, and in Claeys and Hiptmair (Integr Equ Oper Theory 84:33–68, 2016. https://doi.org/10.1007/s00020-015-2242-5) for Maxwell’s equations in frequency domain. The gist is a quotient space perspective that allows to make sense of jumps of traces as factor spaces of multi-trace spaces modulo single-trace spaces without relying on orientation. This paves the way for formulating first-kind boundary integral equations in weak form posed on energy trace spaces. In this article we extend that idea to the Galerkin boundary element (BE) discretization of first-kind boundary integral equations. Instead of trying to approximate jumps directly, the new quotient space boundary element method employs a Galerkin BE approach in multi-trace boundary element spaces. This spawns discrete boundary integral equations with large null spaces comprised of single-trace functions. Yet, since the right-hand-sides of the linear systems of equations are consistent, Krylov subspace iterative solvers like GMRES are not affected by the presence of a kernel and still converge to a solution. This is strikingly confirmed by numerical tests.
Claeys2021_Article_Quotient-spaceBoundaryElementM.pdf (865.87 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03200122 , version 1 (16-04-2021)
Xavier Claeys, Lorenzo Giacomel, Ralf Hiptmair, Carolina Urzúa-Torres. Quotient-space boundary element methods for scattering at complex screens. BIT Numerical Mathematics, 2021, ⟨10.1007/s10543-021-00859-y⟩. ⟨hal-03200122⟩
49 Consultations
68 Téléchargements
