HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Parallelizing Structural Transformations on Tarbres
Paul Iannetta 1 Laure Gonnord 1 Gabriel Radanne 1
1 CASH - CASH - Compilation and Analysis, Software and Hardware
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : Trees are used everywhere, yet their internal operations are nowhere as optimized as arrays are. Our work is in the continuity of the research on cache-oblivious algorithms for trees. In this article, we investigate the parallel properties of Tarbres–an implicit representation for AVL trees. Our first contribution is a new set of structural low-level operations which are needed to efficiently manipulate Tarbres in-place. These operations expose opportunities for further optimisations and parallelization. We provide as a second contribution new implementations which take advantage of these opportunities and proceed to a comparison with the actual expressivity of the polyhedral model framework for loop optimisation. Finally, experimental evaluation highlights the performance advantages of Tarbres.
Complete list of metadata
https://hal.inria.fr/hal-03208466
Contributor : Paul Iannetta Connect in order to contact the contributor
Submitted on : Tuesday, April 27, 2021 - 3:41:07 PM
Last modification on : Monday, May 16, 2022 - 3:06:02 PM
File
rr-9405.pdf
Identifiers
  • HAL Id : hal-03208466, version 1
Collections
Citation
Paul Iannetta, Laure Gonnord, Gabriel Radanne. Parallelizing Structural Transformations on Tarbres. [Research Report] RR-9405, ENS Lyon, CNRS & INRIA. 2021, pp.21. ⟨hal-03208466⟩
Share
Metrics
Record views
47
Files downloads
86
