Homogeneous Observer Design for Finite-dimensional projections of Homogeneous PDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Sufficient conditions for existence and uniqueness of solutions for a coupled system of homogeneous equations defining dynamics of the gain and observer for ODEs obtained as a Galerkin projection of homogeneous PDEs are proposed. The conditions rely upon fundamental concept of uniform complete observability which is also used to design an exponentially convergent observer. Convergence of the observer is confirmed by numerical experiments with ODEs obtained from a hyperbolic PDE in 1D (Burgers-Hopf equation).
paper (1).pdf (480.54 Ko) Télécharger le fichier
hal-03212158 , version 1 (29-04-2021)
  • HAL Id : hal-03212158 , version 1
Sergiy Zhuk, Andrey Polyakov. Homogeneous Observer Design for Finite-dimensional projections of Homogeneous PDEs. 2021. ⟨hal-03212158⟩
38 Consultations
59 Téléchargements
