Stability analysis of car-following systems with uniformly distributed delays using frequency-sweeping approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Access Année : 2021
In this paper, the stability problem of a class of deterministic car-following systems with uniformly distributed delays is addressed with a particular focus on the effects induced by the delay parameters on the stability. To perform such an analysis, the frequency-sweeping approach introduced recently by the authors will be adopted. The corresponding results are easy to derive and to implement. As a byproduct of the analysis, the complete characterization of the delay intervals guaranteeing stability is explicitly derived. Two case studies with different network topology types (linear and ring configurations) are studied in detail. The stability problem of car-following systems under consideration is a specific consensus problem of multi-agent systems. Such examples allow illustrating the approach as well as the positive effect of using uniformly distributed delay in the modeling (compared with the commonly-used pointwise delay). The derived results show that the approach is effective and may be adopted to more general consensus problems for multi-agent systems.
UDDSTraficFlow.pdf (1.03 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03219166 , version 1 (06-05-2021)
Yu-Jiao Chen, Xu-Guang Li, Yingwei Zhang, Silviu-Iulian Niculescu, Arben Cela. Stability analysis of car-following systems with uniformly distributed delays using frequency-sweeping approach. IEEE Access, 2021, ⟨10.1109/ACCESS.2021.3077513⟩. ⟨hal-03219166⟩
85 Consultations
93 Téléchargements
