De Finetti’s Construction as a Categorical Limit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bart Jacobs
  • Fonction : Auteur
  • PersonId : 976960
Sam Staton
  • Fonction : Auteur
  • PersonId : 1099422
This paper reformulates a classical result in probability theory from the 1930s in modern categorical terms: de Finetti’s representation theorem is redescribed as limit statement for a chain of finite spaces in the Kleisli category of the Giry monad. This new limit is used to identify among exchangeable coalgebras the final one.
493577_1_En_6_Chapter.pdf (421.01 Ko) Télécharger le fichier
hal-03232351 , version 1 (21-05-2021)
Paternité
Bart Jacobs, Sam Staton. De Finetti’s Construction as a Categorical Limit. 15th International Workshop on Coalgebraic Methods in Computer Science (CMCS), Apr 2020, Dublin, Ireland. pp.90-111, ⟨10.1007/978-3-030-57201-3_6⟩. ⟨hal-03232351⟩
25 Consultations
21 Téléchargements
