Interferometric Graph Transform for Community Labeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We present a new approach for learning unsupervised node representations in community graphs. We significantly extend the Interferometric Graph Transform (IGT) to community labeling: this non-linear operator iteratively extracts features that take advantage of the graph topology through demodulation operations. An unsupervised feature extraction step cascades modulus non-linearity with linear operators that aim at building relevant invariants for community labeling. Via a simplified model, we show that the IGT concentrates around the E-IGT: those two representations are related through some ergodicity properties. Experiments on community labeling tasks show that this unsupervised representation achieves performances at the level of the state of the art on the standard and challenging datasets Cora, Citeseer, Pubmed and WikiCS.
hal_version.pdf (578.22 Ko) Télécharger le fichier
hal-03247781 , version 1 (04-06-2021)
Nathan Grinsztajn, Louis Leconte, Philippe Preux, Edouard Oyallon. Interferometric Graph Transform for Community Labeling. 2021. ⟨hal-03247781⟩
114 Consultations
87 Téléchargements
