Interacting Weighted Ensemble Kalman Filter applied to Underwater Terrain Aided Navigation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Terrain Aided Navigation (TAN) provides a driftfree navigation approach for Unmanned Underwater Vehicles. This paper focuses on an improved version of the Weighted Ensemble Kalman Filter (WEnKF) to solve the TAN problem. We analyze some theoretical limitations of the WEnKF and derive an improved version which ensures that the asymptotic variance of weights remains bounded. This improvement results in an enhanced robustness to nonlinearities in practice. Numerical results are presented and the robustness is demonstrated with respect to conventional WEnKF, yielding twice as less nonconvergence cases.
DTIS21125.pdf (1.08 Mo) Télécharger le fichier
hal-03248265 , version 1 (03-06-2021)
  • HAL Id : hal-03248265 , version 1
Camille Palmier, Karim Dahia, Nicolas Merlinge, Dann Laneuville, Pierre del Moral. Interacting Weighted Ensemble Kalman Filter applied to Underwater Terrain Aided Navigation. ACC 2021 - American Control Conference, May 2021, New Orleans / Virtual, United States. ⟨hal-03248265⟩
168 Consultations
85 Téléchargements
