Abstract : The present document develops the specification for the discovery solution selected in ETSI TR 103 715 [i.2] and which simulation is documented in ETSI TR 103 716 [i.3]. The present document specifies candidate solutions while the corresponding standardization proposals are contributed to oneM2M TS-0001 (Architecture) [i.5], oneM2M TS- 0034 (Semantic support) [i.7], oneM2M TS-0033 (Interworking Framework) [i.18], oneM2M TS-0004 (Protocols) [i.19] (other oneM2M TS may be also impacted) with the help of the supporting companies active in oneM2M.
https://hal.inria.fr/hal-03261080 Contributor : Luigi LiquoriConnect in order to contact the contributor Submitted on : Tuesday, June 15, 2021 - 2:11:17 PM Last modification on : Sunday, May 1, 2022 - 3:14:36 AM Long-term archiving on: : Thursday, September 16, 2021 - 6:43:44 PM
Seung Myeong Jeong, Sunil Kumar, Andrea Cimmino, Raúl García Castro, Luigi Liquori, et al.. ETSI SmartM2M Technical Report 103717; Study for oneM2M; Discovery and Query specification development. 2021. ⟨hal-03261080⟩
