A Novel Approach Towards Analysis of Attacker Behavior in DDoS Attacks
Traditionally, research in Network Security has largely focused on Intrusion Detection and the use of Machine Learning techniques towards identifying malicious agents as well as work on methods towards protecting ourselves from such attacks. In this paper, we wish to make use of the same techniques to analyze the profile of the attacker in the case of a DDoS attack on a distributed honeypot.
