A refined Weissman estimator for extreme quantiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Extremes Année : 2023
Weissman extrapolation methodology for estimating extreme quantiles from heavy-tailed distributions is based on two estimators: an order statistic to estimate an intermediate quantile and an estimator of the tail-index. The common practice is to select the same intermediate sequence for both estimators. In this work, we show how an adapted choice of two different intermediate sequences leads to a reduction of the asymptotic bias associated with the resulting refined Weissman estimator. The asymptotic normality of the latter estimator is established and a data-driven method is introduced for the practical selection of the intermediate sequences. Our approach is compared to Weissman estimator and to six bias reduced estimators of extreme quantiles on a large scale simulation study. It appears that the refined Weissman estimator outperforms its competitors in a wide variety of situations, especially in the challenging high bias cases. Finally, an illustration on an actuarial real data set is provided.
Weissman_estimator_revisited.pdf (733.06 Ko) Télécharger le fichier
hal-03266676 , version 1 (22-06-2021)
hal-03266676 , version 2 (08-09-2021)
hal-03266676 , version 3 (15-03-2022)
Paternité
Michaël Allouche, Jonathan El Methni, Stéphane Girard. A refined Weissman estimator for extreme quantiles. Extremes, 2023, 26, pp.545-572. ⟨10.1007/s10687-022-00452-8⟩. ⟨hal-03266676v3⟩
437 Consultations
583 Téléchargements
