Phase/Amplitude Synchronization of Brain Signals During Motor Imagery BCI Tasks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Neural Systems and Rehabilitation Engineering Année : 2021
In the last decade, functional connectivity (FC) has been increasingly adopted based on its ability to capture statistical dependencies between multivariate brain signals. However, the role of FC in the context of brain-computer interface applications is still poorly understood. To address this gap in knowledge, we considered a group of 20 healthy subjects during an EEG-based hand motor imagery (MI) task. We studied two well-established FC estimators, i.e. spectral- and imaginary-coherence, and we investigated how they were modulated by the MI task. We characterized the resulting FC networks by extracting the strength of connectivity of each EEG sensor and we compared the discriminant power with respect to standard power spectrum features. At the group level, results showed that while spectral-coherence based network features were increasing in the sensorimotor areas, those based on imaginary-coherence were significantly decreasing. We demonstrated that this opposite, but complementary, behavior was respectively determined by the increase in amplitude and phase synchronization between the brain signals. At the individual level, we eventually assessed the potential of these network connectivity features in a simple off-line classification scenario. Taken together, our results provide fresh insights into the oscillatory mechanisms subserving brain network changes during MI and offer new perspectives to improve BCI performance.
09452143.pdf (62.25 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03285091 , version 1 (13-07-2021)
Tiziana Cattai, Stefania Colonnese, Marie-Constance Corsi, Danielle Bassett, Gaetano Scarano, et al.. Phase/Amplitude Synchronization of Brain Signals During Motor Imagery BCI Tasks. IEEE Transactions on Neural Systems and Rehabilitation Engineering, 2021, 29, pp.1168-1177. ⟨10.1109/TNSRE.2021.3088637⟩. ⟨hal-03285091⟩
68 Consultations
79 Téléchargements
