Towards Extraction of Theorems and Proofs in Scholarly Articles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Shrey Mishra
  • Fonction : Auteur
  • PersonId : 1105903
Lucas Pluvinage
  • Fonction : Auteur
  • PersonId : 1078307
Scholarly articles in mathematical fields often feature mathematical statements (theorems, propositions, etc.) and their proofs. In this paper, we present preliminary work for extracting such information from PDF documents, with several types of approaches: vision (using YOLO), natural language (with transformers), and styling information (with linear conditional random fields). Our main task is to identify which parts of the paper to label as theorem-like environments and proofs. We rely on a dataset collected from arXiv, with LaTeX sources of research articles used to train the models.
without_copy.pdf (1.38 Mo) Télécharger le fichier
hal-03293643 , version 1 (21-07-2021)
  • HAL Id : hal-03293643 , version 1
Shrey Mishra, Lucas Pluvinage, Pierre Senellart. Towards Extraction of Theorems and Proofs in Scholarly Articles. DocEng '21 - 21st ACM Symposium on Document Engineering, Aug 2021, Limerick, Ireland. ⟨hal-03293643⟩
216 Consultations
238 Téléchargements
