A well-conditioned weak coupling of boundary element and high-order finite element methods for time-harmonic electromagnetic scattering by inhomogeneous objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2022
The aim of this paper is to propose efficient weak coupling formulations between the boundary element method and the high-order finite element method for solving time-harmonic electromagnetic scattering problems. The approach is based on the use of a non-overlapping domain decomposition method involving optimal transmission operators. The associated transmission conditions are constructed through a localization process based on complex rational Padé approximants of the nonlocal Magnetic-to-Electric operators. Numerical results are presented to validate and analyze the new approach for both homogeneous and inhomogeneous scatterers.
FemBemWeakcouplingSubmitted.pdf (987.39 Ko) Télécharger le fichier
hal-03305269 , version 1 (28-07-2021)
Ismaïl Badia, Boris Caudron, Xavier Antoine, Christophe Geuzaine. A well-conditioned weak coupling of boundary element and high-order finite element methods for time-harmonic electromagnetic scattering by inhomogeneous objects. SIAM Journal on Scientific Computing, 2022, 44 (3), pp.B640-B667. ⟨10.1109/ACES53325.2021.00144⟩. ⟨hal-03305269⟩
336 Consultations
145 Téléchargements
