Representations of Deligne-Mostow lattices into PGL(3, C) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We classify representations of a class of Deligne-Mostow lattices into PGL(3, C). In particular, we show local rigidity for the representations (of Deligne-Mostow lattices with 3-fold symmetry and of type one) where the generators we chose are in the same conjugacy class as the generators of Deligne-Mostow lattices. We use formal computations in SAGE to obtain the results. The code files are available on GitHub ([FPUP21]).
Deformations4.pdf (383.69 Ko) Télécharger le fichier
hal-03313111 , version 1 (03-08-2021)
Elisha Falbel, Irene Pasquinelli, Alejandro Ucan-Puc. Representations of Deligne-Mostow lattices into PGL(3, C). 2021. ⟨hal-03313111⟩
45 Consultations
38 Téléchargements
