Lessons learnt from the use of compartmental models over the COVID-19 induced lockdown in France - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
Background: Compartmental models help making public health decisions. They were used during the COVID-19 outbreak to estimate the reproduction numbers and predict the number of hospital beds required. This study examined the ability of closely related compartmental models to reflect equivalent epidemic dynamics. Methods: The study considered three independently designed compartmental models that described the COVID-19 outbreak in France. Model compartments and parameters were expressed in a common framework and models were calibrated using the same hospitalization data from two official public databases. The calibration procedure was repeated over three different periods to compare model abilities to: i) fit over the whole lockdown; ii) predict the course of the epidemic during the lockdown; and, iii) provide profiles to predict hospitalization prevalence after lockdown. The study considered national and regional coverages. Results: The three models were all flexible enough to match real hospitalization data during the lockdown, but the numbers of cases in the other compartments differed. The three models failed to predict reliably the number of hospitalizations after the fitting periods at national as at regional scales. At the national scale, an improved calibration led to epidemic course profiles that reflected hospitalization dynamics and reproduction numbers that were coherent with official and literature estimates. Conclusion: This study shows that prevalence data are needed to further refine the calibration and make a selection between still divergent models. This underlines strongly the need for repeated prevalence studies on representative population samples.
Lessons learnt from the use of compartmental models v3.pdf (2.47 Mo) Télécharger le fichier
hal-03341704 , version 1 (12-09-2021)
  • HAL Id : hal-03341704 , version 1
Romain Gauchon, Nicolas Ponthus, Catherine Pothier, Christophe Rigotti, Vitaly Volpert, et al.. Lessons learnt from the use of compartmental models over the COVID-19 induced lockdown in France. [Research Report] Université Lyon 1; Ecole Centrale de Lyon; INSA Lyon. 2021, p. 39. ⟨hal-03341704⟩
126 Consultations
161 Téléchargements
