Attention-based Multiple Instance Learning with Mixed Supervision on the Camelyon16 Dataset - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Proceedings of Machine Learning Research Année : 2021
Since the standardization of Whole Slide Images (WSIs) digitization, the use of deep learning methods for the analysis of histological images has shown much potential. However, the sheer size of WSIs is a real challenge, as they are often up to 100,000 pixels wide and high at the highest resolution, and therefore cannot be processed directly by any model. Moreover, as the manual delineation of structures within WSIs is tedious, histological datasets often only contain slide-level labels, or a limited amount of delineated slides. In this context, multiple-instance learning (MIL) approaches have been proposed, considering WSIs as bags of smaller images, designated as tiles or patches. Among these methods, the attention-based MIL aims at learning the importance of each tile for the slide final classification while at the same time performing a clustering of those tiles. In this paper, we introduce the concept of mixed supervision within this framework, by exploiting tile-level labels in addition to slide-level labels to improve the classification of slides. More precisely, we show on the Camelyon16 dataset that even a small proportion of slides with pixel-wise annotations can improve their classification but also the localization of tumorous regions. This improves the consistency of the results between the tile and slide levels and the interpretability of the algorithm.
Compay_hal.pdf (950.1 Ko) Télécharger le fichier
hal-03342963 , version 1 (13-09-2021)
  • HAL Id : hal-03342963 , version 1
Paul Tourniaire, Marius Ilie, Paul Hofman, Nicholas Ayache, Hervé Delingette. Attention-based Multiple Instance Learning with Mixed Supervision on the Camelyon16 Dataset. MICCAI 2021 - Workshop on Computational Pathology, Sep 2021, Strasbourg, France. pp.216-226. ⟨hal-03342963⟩
241 Consultations
265 Téléchargements
