An Approximation of Minimax Control using Random Sampling and Symbolic Computation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IFAC-PapersOnLine Année : 2021
We aim at the synthesis of an approximate minimax control for a system dynamic given in the form x.(t) = f(x(t),u(t),d(t)) where x represents the state, u the control (or input) and d a disturbance (or perturbation). The disturbance d(t) is prescribed to a compact domain D on which it can take any value (bounded uncertainty). Our method makes use of symbolic computation to enclose the solutions corresponding to all possible disturbance d. in D, together with a simple algorithm of random sampling to select the minimum control u*. We illustrate the interest of this approximate minimax control on an example of a biochemical reactor.
hal-03343147 , version 1 (14-09-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Jawher Jerray, Laurent Fribourg, Étienne André. An Approximation of Minimax Control using Random Sampling and Symbolic Computation. IFAC-PapersOnLine, 2021, Proceedings of the 7th IFAC Conference on Analysis and Design of Hybrid Systems (ADHS 2021), 54 (5), pp.265-270. ⟨10.1016/j.ifacol.2021.08.509⟩. ⟨hal-03343147⟩
49 Consultations
0 Téléchargements
