Effects of the environment and animal behavior on nutrient requirements for gestating sows: Future improvements in precision feeding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) Animal Feed Science and Technology Année : 2021
Taking into account individual variability while feeding a group of sows allows feed cost reductions and therefore improves animal efficiency. This precision feeding strategy is based on 1) nutritional models, which are able to predict daily individual nutrient requirements; 2) automatons, that can deliver individual rations; and 3) new technologies such as sensors which provide real-time information on the animal performance and life conditions that should be integrated into the estimation of requirements. Up to now, only production data (body weight, backfat thickness) have been integrated into the calculation of individual nutrient requirements. However, the literature reported that health status and behavior, such as physical activity, social behavior, and location in the pen, can strongly influence nutrient requirements. A change in the feeding or drinking behavior can also indicate a health or welfare problem. Sensors, automatons and cameras are now able to detect some diseases or injuries, and record certain onfarm behaviors. Therefore, nutrient requirements should be adjusted based on these health and behavioral parameters. Environmental factors such as thermal conditions, housing type and noise level have also been reported to affect nutrient requirements. On-farm sensors can easily be installed to record these parameters to be integrated into the nutritional model and improve its precision. A decision support system can be used to integrate these new measurements into the nutritional model for gestating sows. It would also be helpful to trigger alerts and propose corrective actions when behavior changes or health issues are detected.
Gaillard_2021.pdf (1.82 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03347926 , version 1 (17-09-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Charlotte Gaillard, Maëva Durand, Christine Largouët, Jean-Yves Dourmad, Céline Tallet. Effects of the environment and animal behavior on nutrient requirements for gestating sows: Future improvements in precision feeding. Animal Feed Science and Technology, 2021, 279, pp.1-17. ⟨10.1016/j.anifeedsci.2021.115034⟩. ⟨hal-03347926⟩
115 Consultations
241 Téléchargements
