Explaining Safety Violations in Real-Time Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
We tackle the problem of explaining faults in real-time systems. Intuitively, an explanation of the violation of a safety property by an execution is a concise excerpt of the faulty execution that retains only the elements that were relevant for entailing the violation, thus exhibiting how causes accumulate over time and propagate to entail the effect. Fault explanation therefore goes beyond the well-known concepts of fault diagnosis and localization. We provide a formal definition of causal explanations on dense-time models, based on the wellstudied formalisms of timed automata and zone-based abstractions. Our approach is able to account for limited observability of the faulty execution. We propose a symbolic formalization to effectively construct such explanations, which we have implemented in a prototype tool. We illustrate our approach on several examples.
RR-9420.pdf (987.36 Ko) Télécharger le fichier
hal-03348046 , version 1 (17-09-2021)
  • HAL Id : hal-03348046 , version 1
Thomas Mari, Thao Dang, Gregor Gössler. Explaining Safety Violations in Real-Time Systems. [Research Report] RR-9420, INRIA; Verimag, Université Grenoble Alpes. 2021. ⟨hal-03348046⟩
Relations
144 Consultations
182 Téléchargements
