ICE: Inter-instance Contrastive Encoding for Unsupervised Person Re-identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Unsupervised person re-identification (ReID) aims at learning discriminative identity features without annotations. Recently, self-supervised contrastive learning has gained increasing attention for its effectiveness in unsupervised representation learning. The main idea of instance contrastive learning is to match a same instance in different augmented views. However, the relationship between different instances has not been fully explored in previous contrastive methods, especially for instance-level contrastive loss. To address this issue, we propose Interinstance Contrastive Encoding (ICE) that leverages interinstance pairwise similarity scores to boost previous classlevel contrastive ReID methods. We first use pairwise similarity ranking as one-hot hard pseudo labels for hard instance contrast, which aims at reducing intra-class variance. Then, we use similarity scores as soft pseudo labels to enhance the consistency between augmented and original views, which makes our model more robust to augmentation perturbations. Experiments on several largescale person ReID datasets validate the effectiveness of our proposed unsupervised method ICE, which is competitive with even supervised methods. Code is made available at https://github.com/chenhao2345/ICE.
iccv2021_ICE__Inter_Instance_Contrastive_Encoding_for_Unsupervised_Person_Re_identification.pdf (2.06 Mo) Télécharger le fichier
hal-03349266 , version 1 (20-09-2021)
  • HAL Id : hal-03349266 , version 1
Hao Chen, Benoit Lagadec, Francois F Bremond. ICE: Inter-instance Contrastive Encoding for Unsupervised Person Re-identification. ICCV 2021 - IEEE/CVF International Conference on Computer Vision, Oct 2021, Virtual, Canada. ⟨hal-03349266⟩
69 Consultations
39 Téléchargements
