In-situ visualization using Damaris: the Code Saturne use case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2021
As the exascale era approaches, maintaining scalable performance in data management tasks (storage, visualization, analysis, etc.) remains a key challenge in sustaining high performance for the application execution. To address this challenge, the Damaris middleware leverages dedicated computational resources in multicore nodes to offload data management tasks, including I/O, data compression, scheduling of data movements, in-situ analysis, and visualization. In this study we evaluate the benefits of Damaris to improve the efficiency of in-situ visualization for Code_Saturne, a fluid dynamics modeling environment. The experiments show Damaris to adequately hide the I/O processing of various Paraview processing pipelines in Code_Saturne. In all cases the Damaris enabled version of Code_Saturne was found to be more efficient than the identical non-Damaris capable version when running the same Paraview pipeline.
PRACE_W6_2_Damaris_Integration_with_Code_Saturne_Whitepaper__post_review_2_.pdf (1.11 Mo) Télécharger le fichier
hal-03354035 , version 1 (24-09-2021)
  • HAL Id : hal-03354035 , version 1
Joshua C Bowden, François Tessier, Charles Deltel, Simone Bnà, Gabriel Antoniu. In-situ visualization using Damaris: the Code Saturne use case. 2021. ⟨hal-03354035⟩
169 Consultations
168 Téléchargements
