ETP4HPC's Strategic Research Agenda for High-Performance Computing in Europe 4 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2020
Pascale Bernier-Bruna
  • Fonction : Auteur
Laurent Cargemel
  • Fonction : Auteur
Pascale Rossé-Laurent
  • Fonction : Auteur
Guy Lonsdale
  • Fonction : Auteur
Jens Krueger
  • Fonction : Auteur
This Strategic Research Agenda is the fourth High Performance Computing (HPC) technology roadmap developed and maintained by ETP4HPC, the European High-Performance Computing Platform with the support of the EXDCI-2 project. It continues the tradition of a structured approach to the identification of key research objectives. The main objective of this SRA is to identify the European technology research priorities in the area of High-Performance Computing (HPC) and High-Performance Data Analytics (HPDA), which should be used by EuroHPC to build its 2021 – 2024 Work Programme. Over eighty HPC experts associated with member organisations of ETP4HPC created this document in collaboration with external technical leaders representing those areas of technology that together with HPC form what we have come to call “The Digital Continuum”. This new concept well reflects the main trend of this SRA – it is not only about developing HPC technology in order to build competitive European HPC systems but also about making our HPC solutions work together with other related technologies - the material included in this SRA is also a result of our interactions with Big Data, Internet of Things (IoT), and Artificial Intelligence (AI) and Cyber Physical Systems (CPS).
ETP4HPC_SRA4_2020_web_20200331.pdf (9.79 Mo) Télécharger le fichier
hal-03354396 , version 1 (24-09-2021)
Michael Malms, Marcin Ostasz, Maike Gilliot, Pascale Bernier-Bruna, Laurent Cargemel, et al.. ETP4HPC's Strategic Research Agenda for High-Performance Computing in Europe 4. ETP4HPC: European Technology Platform for High Performance Computing, with the support of the EXDCI-2 project. , pp.1-108, 2020, ETP4HPC White Papers, ⟨10.5281/zenodo.4605343⟩. ⟨hal-03354396⟩
239 Consultations
181 Téléchargements
