Immersive Volumetric Point Cloud Manipulation for Cultural Heritage - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a framework for an immersive and interactive 3D manipulation of volumetric point clouds in virtual reality. The framework was designed to meet the needs of cultural heritage experts such as archaeologists or curators for use on cultural heritage artifacts. We propose a display infrastructure associated with a set of tools that allows users from the cultural heritage domain to interact directly with the point clouds within their study process. The resulting framework allows an immersive navigation, interaction and real time segmentation.
VolumePointCloud_ICAT-hal.pdf (6.55 Mo) Télécharger le fichier
hal-03356642 , version 1 (28-09-2021)
  • HAL Id : hal-03356642 , version 1
Rafik Drissi, Ronan Gaugne, Théophane Nicolas, Valérie Gouranton. Immersive Volumetric Point Cloud Manipulation for Cultural Heritage. ICAT-EGVE 2021 - 31th International Conference on Artificial Reality and Telexistence (ICAT 2021) and the 26th Eurographics Symposium on Virtual Environments (EGVE 2021), Sep 2021, Sankt Augustin, Germany. pp.1-5. ⟨hal-03356642⟩
246 Consultations
89 Téléchargements
