Modelling Systems Biology Wide and Deep - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2021
Biological systems involve a wide amount of different molecular interactions. Each interaction can in turn present a deep level of mechanistic details. Most modelling methods can encompass only one of those two dimensions, that is the width or depth of biological systems. Rule-based modelling is a powerful method in that regard as it can model large systems with mechanistically detailed interactions. The advantage of including mechanistic details is that they allow a clear tracking of causal chains of events between biomolecules. This translates into a precise pinpointing of upstream regulators and a better understanding of complex biological systems.
abstract-CMSB2021-b.pdf (659.95 Ko) Télécharger le fichier
hal-03357485 , version 1 (28-09-2021)
  • HAL Id : hal-03357485 , version 1
Sébastien Légaré, Jean Krivine, Russ Harmer, Jérôme Feret. Modelling Systems Biology Wide and Deep. CMSB 2021 - 19th International Conference on Computational Methods in Systems Biology, Sep 2021, Bordeaux, France. CMSB. ⟨hal-03357485⟩
94 Consultations
60 Téléchargements
