Deciding Non-Compressible Blocks in Sparse Direct Solvers using Incomplete Factorization
Low-rank compression techniques are very promising for reducing memory footprint and execution time on a large spectrum of linear solvers. Sparse direct supernodal approaches are one of these techniques. However, despite providing a very good scalability and reducing the memory footprint, they suffer from an important flops overhead in their unstructured low-rank updates. As a consequence, the execution time is not improved as expected. In this paper, we study a solution to improve low-rank compression techniques in sparse supernodal solvers. The proposed method tackles the overprice of the low-rank updates by identifying the blocks that have poor compression rates. We show that the fill-in levels of the graph based block incomplete LU factorization can be used in a new context to identify most of these non-compressible blocks at low cost. This identification enables to postpone the low-rank compression step to trade small extra memory consumption for a better time to solution. The solution is validated within the PASTIX library with a large set of application matrices. It demonstrates sequential and multithreaded speedup up to 8.5×, for small memory overhead of less than 1.49× with respect to the original version.
main.pdf (521) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-03361299 , version 1 (01-10-2021)
Esragul Korkmaz, Mathieu Faverge, Grégoire Pichon, Pierre Ramet. Deciding Non-Compressible Blocks in Sparse Direct Solvers using Incomplete Factorization. HiPC 2021 - 28th IEEE International Conference on High Performance Computing, Data, and Analytics, Dec 2021, Bangalore, India. pp.1-10, ⟨10.1109/HiPC53243.2021.00024⟩. ⟨hal-03361299⟩
167 Consultations
145 Téléchargements
More
