New interface
Reports (Research report)
Types and sizes
Jens Gustedt 1
1 CAMUS - Compilation pour les Architectures MUlti-coeurS
Inria Nancy - Grand Est, ICube - Laboratoire des sciences de l'ingénieur, de l'informatique et de l'imagerie
Abstract : In 6.5.2 of the C standard, sizes are primarily defined for types. Although this is not stated explicitly, it is commonly assumed that such sizes cannot exceed SIZE_MAX. Sizes of *objects* (in contrast to *storage instances* as of TS 6010) are only a deduced property that is in most cases defined through the type that an object has. This proposal attempts to make this approach consistent throughout the standard, and to reduce the number of marginal cases where the interpretation of sizeof is different between C and C++.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-03363692
Contributor : Jens Gustedt Connect in order to contact the contributor
Submitted on : Monday, October 4, 2021 - 10:39:10 AM
Last modification on : Wednesday, October 26, 2022 - 8:15:24 AM
Identifiers
  • HAL Id : hal-03363692, version 1
Citation
Jens Gustedt. Types and sizes. [Research Report] 2838, ISO JTC1/SC22/WG14. 2021. ⟨hal-03363692⟩
Share
Metrics
Record views
32
Files downloads
