Short-Term Ambient Temperature Forecasting for Smart Heaters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Maintaining Cloud data centers is a worrying challenge in terms of energy efficiency. This challenge leads to solutions such as deploying Edge nodes that operate inside buildings without massive cooling systems. Edge nodes can act as smart heaters by recycling their consumed energy to heat these buildings. We propose a novel technique to perform temperature forecasting for Edge Computing smart heater environments. Our approach uses time series algorithms to exploit historical air temperature data with smart heaters’ power consumption and heat-sink temperatures to create models to predict short-term ambient temperatures. We implemented our approach on top of Facebook’s Prophet time series forecasting framework, and we used the real-time logs from Qarnot Computing as a usecase of a smart heater Edge platform. Our best trained model yields ambient temperature forecasts with less than 2.66% Mean Absolute Percentage Error showing the feasibility of near realtime forecasting.
Short_Term_Forecasting_Smart_Heaters_Time_Seris_Temperatures(42).pdf (751.14 Ko) Télécharger le fichier
hal-03364728 , version 1 (04-10-2021)
Paternité
  • HAL Id : hal-03364728 , version 1
Danilo Carastan-Santos, Anderson Andrei da Silva, Denis Trystram, Alfredo Goldman, Angan Mitra, et al.. Short-Term Ambient Temperature Forecasting for Smart Heaters. 26th IEEE Symposium on Computers and Communications (ISCC 2021), Sep 2021, Athens, Greece. ⟨hal-03364728⟩
157 Consultations
182 Téléchargements
