Isotropic and Non-Isotropic Signaling in Multivariate α-Stable Noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Communications and Networks Année : 2021
A wide range of communication systems are corrupted by non-Gaussian noise, ranging from wireless to power line. In some cases, including interference in uncoordinated OFDMbased wireless networks, the noise is both impulsive and multivariate. At present, little is known about the information capacity and corresponding optimal input distributions. In this paper, we derive upper and lower bounds of the information capacity by exploiting non-isotropic inputs. For the special case of sub-Gaussian α-stable noise models, a numerical study reveals that isotropic Gaussian inputs can remain a viable choice, although the performance depends heavily on the dependence structure of the noise.
EGAN_Frontiers_2021.pdf (858.68 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-03368384 , version 1 (13-10-2021)
Malcolm Egan. Isotropic and Non-Isotropic Signaling in Multivariate α-Stable Noise. Frontiers in Communications and Networks, 2021, pp.1-11. ⟨10.3389/frcmn.2021.718945⟩. ⟨hal-03368384⟩
42 Consultations
53 Téléchargements
