On the formulation and implementation of extrinsic cohesive zone models with contact - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2022
An extrinsic cohesive zone model with a novel unload–reload behaviour is developed in the framework of non-smooth mechanics. The model is extended to include the effects of dynamics with impact, and is discretised in such a way that it can be written as a Linear Complementarity Problem (LCP). This LCP is proved to be well-posed, and to respect the discrete energy balance of the system. Finally, the LCP system is validated numerically, in both statics and dynamics, by simple test cases, and more involved finite element simulations that correspond to standard test geometries in the literature. The results correspond well with those of other authors, while also demonstrating the simulations’ ability to resolve with relatively large time steps while respecting the energetic balance.
note.pdf (1.49 Mo) Télécharger le fichier
hal-03371667 , version 1 (08-10-2021)
hal-03371667 , version 2 (18-01-2022)
hal-03371667 , version 3 (08-08-2022)
hal-03371667 , version 4 (31-08-2022)
hal-03371667 , version 5 (05-09-2022)
Paternité - Pas d'utilisation commerciale - Pas de modification
Nicholas Anton Collins-Craft, Franck Bourrier, Vincent Acary. On the formulation and implementation of extrinsic cohesive zone models with contact. Computer Methods in Applied Mechanics and Engineering, 2022, 400, pp.115545. ⟨10.1016/j.cma.2022.115545⟩. ⟨hal-03371667v5⟩
296 Consultations
250 Téléchargements
