Correlated Pseudorandom Functions from Variable-Density LPN - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Elette Boyle
  • Fonction : Auteur
  • PersonId : 1113020
Geoffroy Couteau
Niv Gilboa
  • Fonction : Auteur
  • PersonId : 1113021
Yuval Ishai
  • Fonction : Auteur
  • PersonId : 1113022
Lisa Kohl
  • Fonction : Auteur
  • PersonId : 1113023
Peter Scholl
  • Fonction : Auteur
  • PersonId : 1113024
Correlated secret randomness is a useful resource for many cryptographic applications. We initiate the study of pseudorandom correlation functions (PCFs) that offer the ability to securely generate virtually unbounded sources of correlated randomness using only local computation. Concretely, a PCF is a keyed function F k such that for a suitable joint key distribution (k 0 , k 1), the outputs (f k0 (x), f k1 (x)) are indistinguishable from instances of a given target correlation. An essential security requirement is that indistinguishability hold not only for outsiders, who observe the pairs of outputs, but also for insiders who know one of the two keys. We present efficient constructions of PCFs for a broad class of useful correlations, including oblivious transfer and multiplication triple correlations, from a variable-density variant of the Learning Parity with Noise assumption (VDLPN). We also present several cryptographic applications that motivate our efficient PCF constructions. The VDLPN assumption is independently motivated by two additional applications. First, different flavors of this assumption give rise to weak pseudorandom function candidates in depth-2 AC 0 [⊕] that can be conjectured to have subexponential security, matching the best known learning algorithms for this class. This is contrasted with the quasipolynomial security of previous (higher-depth) AC 0 [⊕] candidates. We support our conjectures by proving resilience to several classes of attacks. Second, VDLPN implies simple constructions of pseudorandom generators and weak pseudorandom functions with security against XOR related-key attacks.
2020-1417.pdf (1.03 Mo) Télécharger le fichier
hal-03374160 , version 1 (11-10-2021)
  • HAL Id : hal-03374160 , version 1
Elette Boyle, Geoffroy Couteau, Niv Gilboa, Yuval Ishai, Lisa Kohl, et al.. Correlated Pseudorandom Functions from Variable-Density LPN. FOCS 2020 - Annual IEEE Symposium on Foundations of Computer Science, Nov 2020, Durham, United States. ⟨hal-03374160⟩
44 Consultations
192 Téléchargements
