Brain-Computer Interface using OpenViBE, an open-source software platform for Brain-Computer Interfaces [hands-on tutorial] - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
OpenViBE is a software platform dedicatedto designing, testing and using brain-computerinterfaces (BCIs). It can be used toacquire, filter, process, classify and visualizebrain signals in real time. During thefirst part of the session, ageneral overviewof the BCI context and of the softwarewill be given. We will also present severalexamples of use of OpenViBE in the BCIdomain. During the second part, we willpropose a step-by-step tutorial in whichparticipants will design a simple motor imagerybased BCI scenario from pre-recordedEEG signals.
CuttingEEG_OV_HAL.pdf (79.74 Ko) Télécharger le fichier
HandsOn_OV_CuttingEEG_2021.pdf (3.15 Mo) Télécharger le fichier
hal-03374960 , version 1 (20-10-2021)
  • HAL Id : hal-03374960 , version 1
Arthur Desbois, Marie-Constance Corsi. Brain-Computer Interface using OpenViBE, an open-source software platform for Brain-Computer Interfaces [hands-on tutorial]. CuttingEEG - 5th Symposium on cutting-edge methods for EEG research, Oct 2021, Aix-en-Provence, France. ⟨hal-03374960⟩
109 Consultations
640 Téléchargements
