Generalized Homogenization of Linear Observers: Theory and Experiment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2021
A procedure of upgrading a linear observer to homogeneous (nonlinear) one is proposed and validated by experiment. The nonlinear observer design is based on the the concept of a linear geometric homogeneity. The simple procedure developed to apply the homogeneous nonlinear observer is based on the parameters provided by the linear observer, which is potential for many applications to improve their performance. A saturation function is introduced to guaranteed the improvement of estimation quality. Finally the theoretical results are confirmed by the QDrone platform of Quanser T M .
Automatique
Vf.pdf (799.96 Ko) Télécharger le fichier
hal-03382805 , version 1 (18-10-2021)
Siyuan Wang, Andrey Polyakov, Gang Zheng. Generalized Homogenization of Linear Observers: Theory and Experiment. International Journal of Robust and Nonlinear Control, 2021, ⟨10.1002/rnc.5771⟩. ⟨hal-03382805⟩
66 Consultations
108 Téléchargements
